(15August13) This issue will review making lead sink weight for your rudder. The 1 September issue will show how to rig a lugsail.
Making Sink Weights
WHY SINK WEIGHTS????....
MELTING THE LEAD...
This is Tidmarsh's setup.
Cormorant
All best, Garth
15feb13, Drawing Boats 3, IMB
15may13, Drawing Boats 7, Roar2
1jun13, Drawing Boats 8, Polepunt
15jun13, Rend Lake 2013, Toto
1jul13, Drawing Boats 9, AF4 Grande
15jul13, Taped Seams, Mikesboat
