(1 November 2012) This issue will review capsize lessons learned at Sail OK. The 15 November issue will continue the sail sizing essay.
![]() | Left:
After Sail OK Kathy and Chris cruised the Arkansas River in full autumness. |
Capsize Lessons
RICHARD WOODS...
TO START WITH...
THEN...
ONCE THE BOAT IS RIGHTED...
ANYWAY...
THE DEMONSTRATION...
THEN THEY DID IT AGAIN...
Piccup Pram
Here is another by Doug Bell:
This one is by Jim Islip:
And this one by Ty Homer:
1dec11, Taped Seams, Trilars
1jan12, H14 Rig, Olive Oyl
15apr12, Rowboat Setup, Toon2
15jun12, Rend Lake 2012, Toto
