(1February 2011)This issue will be about knockdown recovery. The 15 February issue will show a way of mounting a windsurfer sail on a small boat.
BUT DUCKWORKS IS ON VACATION UNTIL FEB 15, SO...
...in the meantime you can still order direct from me with a check in the mail. Direct orders do not need the Duckworks handling fee so save $5 there. US and Canadian orders get airmail delivery included in the basic price. Overseas orders please add $10 for shipping. I have a Paypal account so you can also use a money transfer through Paypal if you wish for faster service and email your order to me at jim@jimsboats.com. Paypal orders must include the Duckworks handling fee.
Knockdown Recovery 2
THE CAPSIZE...
UPDATE 2007...
...I heard of three capsizes with swampings this year, two in AF3 and one in a Frolic2. What they all had in common was someone standing in the open slot top at the time. Clearly that won't work - the weight has to be in the cockpit and the slot well covered and secured.
LADYBUG CAPSIZE UPDATE:
MORE PONDERING...
Caroline
CAROLINE, SAILBOAT, 18' X 6', 750 POUNDS EMPTY
Caroline started as a blend of Philsboat and Frolic2. The idea was for a little more cabin room than Philsboat and hopefully with the same seakeeping ability that Frolic2 has demonstrated. I made it a little deeper and wider and with a longer cabin than Philsboat. It all added up to about 30% more cabin volume. But it is also more boat to build and pay for and haul so the other boats, which are lighter and cheaper, still haven�t been made obsolete as far as I am concerned.
One interesting side to this sort of house design is that if you add a motor well, as this one has, the stern gets pretty busy since the only way you can run a normal tiller to the rudder is under the aft deck. To get a good swing of the rudder that aft deck needs to be short and wide if that motor is to live there too. I think I have it all crammed in there such that it might work but even so the rudder is well offset to one side, as it was successfully done with Philsboat.
The builder wanted a yawl rig (she wants to coastal cruise the Maine coast) but I added the mizzen as I do now, keeping the basic balance such that you could sail it without the mizzen.
You can see that these Birdwatcher cabins are simple and roomy.
There was another Caroline built in Texas, Chris's EZBake. It was a veteran of the Texas200 in its first year fitted with a Chinese lug sail that was replaced later with the blueprint rig. I got a chance to ride in it for a few hours at the Sail Oklahoma 2010. Here is Chris anchored by the stern on a lee shore at our picnic beach...
And again after the picnic after returning to the home beach...
A note about Chris's Caroline. He has enlarged his stern well to be the full width well I normally like to use. But it won't usually work with a Birdwatcher because with this style cabin the tiller must run under the stern deck and into the cabin. If you do that with a large full width motor well you will end up with a long slot for the tiller which is a danger in a knockdown since water could come through it and swamp the cabin. So what you have to do, which is what I did on the Petesboat design and which Chris reinvented here, is to put a short control arm on the side of the rudder and control that with a push/pull stick that runs into the cabin through a small hole in the aft bulkhead on centerline. So this boat has a simple push/pull stick control which takes a while to get used to and has less precise control since the control arm is maybe 18" long instead of maybe 60" long for the standard tiller. Chris had it all figured correctly and feels like I do that the only cure is a geared tiller linkage like I drew on Petesboat. So far Chris has opted for simplicity.
Looks like six sheets of 1/4", ten sheets of 3/8" and three sheets of 1/2"". Taped seam construction.
Plans for Caroline are $50.
15feb10,IMB Capsize Test, IMB
15jul10,Texas200a, Mikesboat
15aug10,Texas200c, Cormorant
