Specifications
- LOA
- 19'6"
- Beam
- 5'7"
John WelsfordOfficial Page
jwboatdesigns.co.nzAdded
Long Steps
by John Welsford
Long Steps is a small cruising sailboat by John Welsford, conceived specifically for extended coastal travel in demanding conditions. The design brief centered on covering long distances efficiently and comfortably along exposed coastlines—particularly those of New Zealand—where safe harbors may be widely spaced and weather can deteriorate quickly. Rather than pursuing outright speed, Welsford prioritized a high, sustainable average speed across a wide range of conditions, along with a hull and rig that reduce fatigue for a solo skipper. Key requirements included good performance on all points of sail, light helm loads, easy sail handling, the ability to hold a course without constant attention, and enough protection from wind and spray to make consecutive long days practical.
Just under 20', Long Steps combines features from several of Welsford’s earlier designs, notably Walkabout and SCAMP. The narrow hull can be rowed, while water ballast (approximately 300 lbs) and extensive built-in buoyancy—over two tons—support offshore safety and self-rescue. A self-draining cockpit, a small raised cuddy used primarily for storage and flotation, and generous internal volume for supplies reflect its intended role as a solo or short-handed expedition boat capable of carrying a week’s worth of gear. The hull form emphasizes a dry, easily driven motion, and the rig—a lug yawl used on several of Welsford’s cruisers—favors balance, simplicity, and low loads. Taken together, Long Steps represents a focused response to the practical realities of long-distance coastal cruising in a compact, trailerable craft.
Photo Credits:
Ruth Vaughan/Facebook
Small Craft Tasmania/YouTube
