(15 July 2022) We review lugsail rigging. The 1 August issue will review horsepower.
Rigging Lugsails
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
Nothing fancy needed here. Almost anything will work. Because the sail is balance already to a great degree the sheet forces are less than with other sail types. Because the tack is pulling down in the middle of the boom, the boom has less tendency to lift so downward pull of the sheet on the boom is of less importance. The location and lead directions of the sheet are of little importance also. It's another advantage of the balanced boom. By the way, if the boom is omitted to make the sail boomless, the sheet location is very critical and its needs change all the time. I think the boom is a great invention! The boom on a balanced lug can be quite light and still work.
SAILING ADVICE...
Also it should be mentioned that one of the most effective ways to trim the boat, helm-wise, is to rake the mast as required to move the sail area fore or aft. You can see that a small amount of rake will move the mast head quite a bit and the entire sail will go with the masthead. Old time boats had adjustable mast steps or partners. On my designs you can usually shim the mast partner on the bulkhead. It's one place where tinkering pays off. Making a mast a bit longer than shown on the plans is also almost always a good idea as it allows for this tinkering not to mention real life stretch of the rigging.
FROLIC2
And Gary Blankenship's Frolic2 completed the Everglades 300 mile challenge with him reporting sailing for hours at 7 knots or more. Last count he completed five of the challenges with a 4th overall in 2007 and 7th in 2012. Here is Gary's Frolic2:
Plans for Frolic2 are $35.
1may22, AF3 Capsize, Blobster
