(1July2011)This issue will be about rigging your trailer. The 15 July issue will sew up a new bimini for my AF4.
Three cheers for Chuck Pierce! He completed this year's very windy Texas200 in his new, but thoroughly tested, Mayfly14. He carried all his gear and supplies with him for the five day event.
jim@jimsboats.com
Trailering
TRAILERING PLYWOOD BOATS
...WHEN TO TRAILER...
...TOW VEHICLE...
...TRAILER TYPES...
A low trailer is best.
...CUSTOM BUNKS...
...TONGUE WEIGHT...
...NOW FOR THOSE BUNKS...
WINCH POST
...GOAL POSTS...
...SIDE BUNKS...
...TIE DOWNS...
Between the two lines and the goal posts, there is redundancy. Only two of the three are needed to secure the boat. And yet untying the boat is a 30 second operation with no loose lines to keep track of. The bow line stays with the boat and the aft line stays with the trailer. .
..LIGHTS... Trailer lights should be unplugged before dunking in the water.
...FINALLY.....
Wooboto
WOOBOTO, SAILBOAT, 15' X 4.5', 200 POUNDS EMPTY
Steve Chambers out in California had built a Roar2 very quickly, in two or three weeks as I recall, and had gone off rowing with it and liked it a lot. He started looking for a design to learn sailing. He was thinking of my old Woobo design but got to really like the Roar2 bow which evolved from Toto. Could the two ideas be combined, a Woobo with a Toto bow. Would it be called Wooboto. Why not? And thus it came to be.
I knew that Steve worked quickly. He started straight off and I saw no need to release Wooboto in a prototype stage since it would be a "done" design in no time. Steve did a great job of it.
I wanted to show this photo to illustrate the one problem he had with assembly. He assembled it as I called for in the drawing with the sides attached to the forms and bulkheads and the wales added as shown. But the problem was that the sides, especially in the bow, are flimsy at this stage and the stiff wales pushed the sides down an inch or so as the wales themselves were bent upward. He noticed the problem at this stage and adjusted the forward form so that the bottom did not bend downward too, then he had to adjust the bilge panels a bit to fit. So from now on with designs of this shape I am going to change the assembly method so that the wales are not added until the bilges are installed to stiffen those narrow sides. Steve quickly pressed on to this stage:
You see that Wooboto has a simple spare structure. No interior seats and no motor well. And then on to this:
A quick clean job. By this time he had already made a polytarp sail from the Mayfly drawings shown in my book, a 75 sq ft job. But he launched it first as a rowing boat without its decks:
He made those oars too. He practiced sailing for a few weeks:
And then off on a cruise of several days with a club of pretty boats in the Sacramento Delta area as I recall:
A wonderful story!
Plans for Wooboto are $40.
15jul10,Texas200a, Mikesboat
15aug10,Texas200c, Cormorant
15jun11, Rend Lakw 2011, Toto
