(1December) This issue will rerun the taped seam essay. The 15 December issue will rerun the bulkhead bevel issue.
Taped Seams
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
Trilars
1oct11, Boat Costs, Larsboat
