(1 November 2018) We will make some sink weights. The 15 November issue will take a look at Piccup Pram spinoffs.
Making Sink Weights
WHY SINK WEIGHTS????....
MELTING THE LEAD...
This is Tidmarsh's setup.
Looks like maybe a plumber's melting stove with a pail of wheel weights on top. I also use wheel weights which I got from my local tire guy (UPDATE HERE. Now modern wheel weights are not lead and won't melt this way.) For heat I use the normal campers propane stove. For a pail I use a coffee can with a handle bolted to it. There is a pour hole on mine about half way up the side of the can so I don't have to tip the can all the way to pour the lead and there is little chance of it sloshing over the top by accident. The pour hole is too small to pass the steel clips of the wheel weights (they float nicely on top of the molten lead).
Shanteuse
There was a Shanteuse built in Florida by Vince SantaMaria a couple of years back but he stretched his to 24' so I couldn't really call that one a Shanteuse. But here is one by Douglas Snelson in Tennessee that looks to be right to the plans so I will call this one the prototype. He sent a bunch of photos:
As for operation, these are smooth water boats. So it is best to stay on small waters that never get too rough. On bigger waters you need to watch the weather very carefully. For power I would stick to 5 or 10 hp but I'm very much a chicken about these things.
Plans for Shanteuse are $35.
1jan18, Trailering, Normsboat
1feb18, Bulkhead Bevels, Toto
15feb18, Sail Rig Spars, IMB
