(15 November 2020) We see Herb McLeod weigh his OliveOyl in a unique way. In the 1 December issue Herb shows us around his new junk rig.
NO MORE ORDERS UNTIL 2021, MAYBE ???
...an update from my blueprint paper supplier, Freedom Paper in Houston, is that they were unable to locate any coating material for Diazit process blueprinting. Not in the US or Asia. So it is kaput, no chance. Looking deeper into getting scans of my mylar tracings. Chuck L sent a tally of last years sales and we figure if we scan the the top twenty or so that will cover most of the income. I am still hunkered down due to the virus and don't see it going away soon, but I think getting scans will take a lot of leg work around here, including getting trials to assure quality. When done, you will be able to order those downloads. So the plan now is to eventually continue the catalog. Right now you can download files for Jonsboat and Toto from Duckworks. These are not scans of my originals but rather are cad works done by kind and interested customers.
Left: DON'T CLEAN THAT SCUM LINE! We need it for something.....
Herb Weighs OliveOyl
Herb McLeod, up in Canada, wrote...
Hi Jim,
It is getting cool here. We have now had three frosts and they are forecasting a possible snow fall on Monday. We are ready for this weather event having completed the fall garden cleanup; placed the snow tires are on the car and taken OliveOyl is out of the water.
OliveOyl spent all of this Covid-19 summer in the water and when I pulled her out and up on the blocks I noted that there was a distinct line all around the boat showing exactly what part of the hull was under water while moored to the dock. (See attached pictures}.
After your recent essays on calculating the displacement of a design I thought to myself, �I can figure out how much my version of OliveOyl weighs!� My OliveOyl sits on the water leaning to the starboard side. I then measured the depth at midpoint on both port and starboard and where at the bow and the stern the hull exited the water on both sides. Next I pulled out the lines drawing and drew lines representing the starboard (green) and port (red)water lines and a third line (blue)in the middle that halved measurement differences between the starboard and port. (There was a goof in my initial measurements so there are two red and two green lines.) All three lines are parallel so using the middle line I worked out on the plans a curve of areas for this water line.
My OliveOyl was built from 3/8 spruce ply for the sides and 5/8 on the bottom. One sheet of 3/8 spruce ply weighs 30 pounds which is the same weight as a sheet of � inch fir plywood but the boat gains an extra quarter inch of beam and an extra 1/8 inch of depth on the outside chines due to the thicker plywood. I took all this into account in my calculations. When tied to the dock the mast and sail are not onboard and the ballasted rudder is raised to be completely out of the water.
My calculations showed that OliveOyl with the hatch cover on but without mast and sail was displacing 651 pounds.
Next I subtracted the following: 100 pounds of lead ballast, 25 pounds for the electric motor and mount, 10 pounds (estimated) for the anchor and chain, 30 pounds (estimated) for other gear, Life jackets, cushions, tools, spare parts, fire extinguisher, paddle, boom crutch, bucket, step-stool, boarding ladder.
This indicates to me that the OliveOly hull weighs 486 pounds which is close enough for me to your estimate of 500 pounds.
Working backwards from the Curve of Areas calculation, I calculated that the Prismatic Coefficient for the OliveOly when moored dockside is 0.57.
There are no surprises in any of this but I have always wondered what OliveOyl weighs. I now think I have a pretty close estimate short of driving 8.5 Kilometers to the local gravel quarry and then begging them to weigh my rig twice, both with and without the boat.
Cheers and stay safe, Herb
Piccup Pram
I think my own Piccup has had about six rigs of different sorts and was always the test bed for the polytarp sail experiments. But, hey!, that's nothing compared to the tinkering the late and great Reed Smith did with his out in California. Here is his Piccup rigged as a sharpie sprit yawl!
Here is another by Doug Bell:
This one is by Jim Islip:
And this one by Ty Homer:
1dec19, Taped Seams, Ladybug
15jan20, Trailering, Robote
1feb20, Bulkhead Bevels, Toto
15feb20, Cartopping, IMB
1aug20, Prop Slip, Oracle
