(15 July 2020) We rig a lugsail. The 1 August issue will look at prop "slip".
Rigging Lugsails
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
Nothing fancy needed here. Almost anything will work. Because the sail is balance already to a great degree the sheet forces are less than with other sail types. Because the tack is pulling down in the middle of the boom, the boom has less tendency to lift so downward pull of the sheet on the boom is of less importance. The location and lead directions of the sheet are of little importance also. It's another advantage of the balanced boom. By the way, if the boom is omitted to make the sail boomless, the sheet location is very critical and its needs change all the time. I think the boom is a great invention! The boom on a balanced lug can be quite light and still work.
SAILING ADVICE...
Also it should be mentioned that one of the most effective ways to trim the boat, helm-wise, is to rake the mast as required to move the sail area fore or aft. You can see that a small amount of rake will move the mast head quite a bit and the entire sail will go with the masthead. Old time boats had adjustable mast steps or partners. On my designs you can usually shim the mast partner on the bulkhead. It's one place where tinkering pays off. Making a mast a bit longer than shown on the plans is also almost always a good idea as it allows for this tinkering not to mention real life stretch of the rigging.
VAMP
VAMP, LIGHT ROWBOAT, 12' X 3.5', 60 POUNDS EMPTY
After the success Frank Kahr had with Robote I designed a smaller version with most of the same features. The idea was to get a fast and seaworthy boat that would cartop so easily that you would want to leave it on the car top more or less all the time, ready to go at a moment's notice. From cartopping smaller boats like Toto I had found that they hardly slow the car down or keep a compact car from getting 30+ miles per gallon on the highway. I thought the trick was to keep the boat small enough that complicated tie downs were not required. I also knew that Piccup, at about 90 pounds, is about the most a fellow would want to cartop. Lighter is better, of course, but once the weight gets below 70 pounds the boat becomes so easy to load that getting it super light is not mandatory. The prototype Vamp that you see here was built by Ken Prims of Layton, Utah. Here is his boat atop his compact car, a very nice package as I had hoped.
Why not stick to a canoe like Toto? It has the size, weight and shape (mild sheer and squared stern) that makes for easy cartopping. But a good rowing boat can be as fast, dryer, and take a passenger with more ease. The only problem I see with Vamp is that her V bottom can make beaching more challenging than a boat with a flat bottom plank.
Construction is with taped seams from three sheets of 1/4" plywood, the same bill of materials as for the larger Robote. Robote will be a lot better if you are rowing with a passenger all the time. Vamp might be a handier impulse boat for a solo boater, although it can take two adults in a pinch.
Vamp plans are $20.
15aug19, Rowing1, Cormorant
1sep19, Rowing2, OliveOyl
1dec19, Taped Seams, Ladybug
15jan20, Trailering, Robote
1feb20, Bulkhead Bevels, Toto
15feb20, Cartopping, IMB
