(1 September 2022) We measure prop thrust. The 15 September issue will cover leeboard issues.
Measuring Prop Thrust
"THE MOST SIGNIFICANT NEGATIVE EXPERIMENT IN THE HISTORY OF SCIENCE"!!!Before I get started talking about propeller thrust I want to set the stage with a dedication to Albert Michelson who spent his life measuring the speed of light. Born in Poland, his family came to the US when he was a little boy. He became expert with optics. In the mid 1800's the speed of light was known in a general way and Michelson, along with his helper Morely, made a device that would measure the speed of light to a degree of accuracy never known before. In fact they thought it so fine as to measure the effect of the earth's orbital movement on the speed of light according to the "ether" theory of light propogation that was current at that time. So they measured and measured and measured. They did indeed zero in on the speed of light but saw no orbit effects. The speed of light was the same no matter how it was measured. Michelson had enough confidence in himself that he published the results even though there was no explanation to be had. That was in 1883. Then in 1905 along comes young Albert Einstein who knows about Michelson's results. Einstein doesn't really explain it except maybe to say "accept it because that is the way it has been proven. The speed of light is always the same no matter how you measure it." And with that basis Einstein went on to figure his theory of relativitly and the rest is history. So just because you can't explain something you measured doesn't mean it is wrong.
NEXT...
PROPELLOR THRUST....
SO I MAKE A THRUSTOMETER...
DOES IT REALLY WORK?????
...UPDATE.... I GOT AN EMAIL FROM EINSTEIN...
... actually I have forgotten his real name, it was long ago. He read the above article and replied that the very best water propellers have an efficiency of about 50%, no higher. And 30% from a standard old propeller is about the right answer. I suppose the wasted power goes into stirring up the fluid.
OliveOyl
Herb McLeod completed the first OliveOyl up in Canada. He also made an AF3 long ago and has been sailing them together and noting the pros and cons of both.
Plans for OliveOyl are $35.
1may22, AF3 Capsize, Blobster
1aug22, Horsepower, Oracle
