(15 December 2018) We will look more at electric power. The 1 January issue will review our sail area math.
REND LAKE 2019...
Left: The Captain directs and Gene Berry obeys on his PaddlePlank.
Electric Boats 2
FIRST A BIT OF REVIEW...
Lead and acid batteries are still the best bet for common electric boats since they are cheaper, more available, and lighter (believe it or not) than other suitable batteries. The battery used to start an auto or boat engine is a poor choice for an electric boat power source since they are designed to give a short big jolt of power, not a long even current like a deep cycle trolling motor battery. Deep cycle batteries are usually rated in "amp-hours" by how many amps of current it can deliver over a 20 hour period. Thus a "100 amp-hour" battery can deliver 5 amps per hour for 20 hours for a total of 100 amp hours. But small trolling motors usually draw about 20 amps per hour (at 12 volts). The higher current draw greatly reduces the total amout of current the battery will deliver. Here is a typical curve for a typical 100 amp-hour battery:
So the 20 amp motor will drain the battery in about 3.2 hours, about 70 amp hours total. Also it is best to not drain a battery below 70% of its total to prevent harming it in a way which will prevent future chargings. So the battery here might be limited to .7 x 3.2 hours = 2.2 hours.
Another recommended limit on the battery operation would be to keep current draw per hour within 20% of the total. So in this case the 20 amp motor is about the max to use with this battery.
Finally, a rough guess at trolling motor horse power is apply the conversion of 1 hp equals 750 watts. A 12 volt motor using 20 amps is using 240 watts, or 240/750 = .32 hp.
In Douglas Little's book ELECTRIC BOATS he presents some power measurements from typical trolling motors. Remember that his "horse power ratings" are based on current measured TO the motor and not the acual measured output of the motor. Here is a chart I made from some of his tests:
Finally, here is a new chart of approximate boat performance, speed vs hp, that is in Little's book. This sort of chart takes no account of "fast" and "slow" hull shapes so is only a very general starting point for figuring performance.
...NEXT, I GOT THIS LETTER...
...after posting the last issue. It was from Clyde Osterhout:
"I know from reading your past articles on the subject that you aren't a really big fan of electric boats. I can't really argue with much that you have said, but my personal experience with the RANGE of electric boats is quite different from your own. For the past 12 years, I have been using several trolling motors with my 17' Grumman Eagle canoe. Most of the time, I have been cruising on mainly flat waters with mild to moderate (1-3 mph) currents. These include the St. Lawrence River, in the 1000 Islands area, the Pocomoke River system in MD, the Susquehanna river, near Three Mile Island, and various lakes and ponds around the Mid-Atlantic region. Maybe 2500 miles or so under power in all. Here are a few observations:
1.With a canoe, at full power, I get about 6-8 miles out of a charge. At 3/4 power, I get about 8-10 miles. I never had enough patience to see how far I could go on anything less. I have discovered that I can go considerably farther with the canoe than the manufacturers estimate I should be able to go. That's because their estimates are based on much heavier boat, with a great deal more resistance to forward motion. I doubt that a converted row boat would be as successful as my canoe. I conclude therefore that an electric boat ought to be narrow, long, and as light as possible. Anything "extra" will reduce range.
2. The motors seem to propel my canoe at about 3.25 mph at the highest setting. That's true of an 18 lbs of thrust motor, as well as a 30 lbs motor. The 30 lbs motor has a great deal more "kick", and works much better in the wind, but the top speed does not seem to be much different. This must be due to the props, as you have already observed. I just obtained an older 30 lbs trolling motor with a small, 3 bladed prop that seems to push my canoe MUCH faster, maybe as much as 5 MPH. I haven't had a chance to do any real testing yet, but it is obvious that prop design is very important for electric powered boats.
3. Electric boats aren't fast. That much is painfully obvious! But the trolling motor powered canoe can maintain a higher average speed than one that is paddled by average paddlers. It works better in windy conditions, and is great for going against a stiff current. It is also quiet, even quieter than paddling. And if one has kids (as I do), it helps to have a free hand or two to deal with them as they squirm around. Finally, many lakes here in PA won't allow anything BUT electric motors, making the choice of what kind of power to use an easy one. So one can find some truly practical reasons for using a motor.
4. DO NOT USE an electric motor in salt water unless it is specifically designed for salt water use. It does ugly things to an electric motor.
What I would love to find would be a "cruising canoe", a long (16-18 foot), narrow (36-40 inches, max), light (less than 120 lbs) boat with a minimal cabin (for changing, napping, or bathroom purposes, not really for camping) kind of thing that would be good for bird watching, swimming, and good clean quiet family fun. Any chance? Hey, a guy can dream, can't he?
Yes, I use 120 amp deep cycle trolling motors. They make a huge difference. Car batteries, as you have pointed out, simply don't work. And not all deep cycle batteries are the same. Sears Die Hards, for instance, consistently put out more "umph" than Walmart batteries of the same amperage. Never could figure out why. They all seem to last about the same length of time, though.
In the end, electric boats aren't about getting anywhere. They are about enjoying the ride itself. Thanks for putting up with my endless observations! Clyde"
SPORTDORY
SPORTDORY
Sportdory plans are $20.
1jan18, Trailering, Normsboat
1feb18, Bulkhead Bevels, Toto
15feb18, Sail Rig Spars, IMB
