(15 September 2022) We cover leeboard issues. The 1 October issue will calculate displacement.
Leeboard Issues
THE VERY BASICS...I've covered sizing and placing of leeboards in previous issues that you can find down in the Way Back Issues link. But to recap, the things you might remember are that the immersed area of the board should be about 4% of the sail area, and that the leeboard must be mounted at the hull's widest beam in order to be in flow parallel to the boat's motion. The suggestion on area would apply to any board such as a centerboard or a daggerboard (but those boards need not be limited to mounting at the boat's widest beam). Lastly, the sail area has to be aligned with its sail area center right above the center of the board's area, more or less.
Here is an example of a leeboard on Slam Dink.
Notice that it pivots around a bolt which is placed to allow the board to retract fully above the bottom of the hull. You can't tell from the drawing but the pivot bolt runs through a lower hull guard and the top of the leeboard runs in a slot in an upper hull guard. The board is thus braced to take loads in both directions, unlike a tradional loose leeboard. As a result only one of these pivoting leeboards is needed on the boat, it works on both tacks, where the tradional loose leeboard only works on the lee tack so two are required. In truth these pivoting leeboards aren't really leeboards but are more like centerboards mounted outside the hull. While sailing you handle it just like a centerboard - just leave it down almost all the time except maybe while running and broad reaching. But I'm still going to call it a leeboard.
The pivoting leeboard has several advantages. They are easily built and altered. There are no holes required through the hull except for the pivot hole. Best of all the leeboard takes up no room on the boat's interior. On the Slam Dink that same board mounted as a centerboard would take up the whole interior. You could see the same situation below on Richard Spelling's AF2 (shown with an experimental mizzen sail).
HANDLING THE LEEBOARD...
I've found that no ballast is required for these boards, they are laminated from layers of plywood with the edges streamlined. If they are loosely pivoted they have a natural tendency to drop down a bit so that they might drop about 20 or 30 degrees until the buoyancy of the immersed segment balances the weight of the board. If you are trailering your boat it is often prudent to secure the board in the full up position so it doesn't catch on things while launching. That happened to me once while launching my Birdwatcher which has a conventional centerboard. I bashed away at it perplexed until the tiny voice of a six year old watching said, "Mister, that board thing on your boat is catching your trailer."
So in that AF2 photo Richard is releasing a line that secures the leeboard in the up position.
How to get the board down? Easy. There is an ear attached to the upper aft edge of the leeboard that sticks up through the upper guard and there is a lanyard attached to it. Grab the lanyard and pull back on it and the leeboard rotates down until it goes kerplunk against the aft end of the slot in the upper guard. Here is Richard hauling the board down.
Once the board is down it prefers to stay down, especially if there is a bit of friction between board and guards applied by tightening the pivot bolt. There are two things that can make it pop up. First if it strikes something like a stump or the bottom. Second is drag on the board when there is no side load on the board such as when running downwind or sometimes when tacking through the eye of the wind.
Once that happens the board will pop up to its comfortable 20 or 30 degree position and stay there until you yank it back down. In the partially down postition the board will still provide skeg effect when running downwind. But some boats will steer better downwind if the board is pulled down again and you might experiment with that. In the situation where the board pops up while tacking through the eye of the wind, you must pull it back down again to sail on the new tack. As always, if the boat suddenly feels funny while tacking through the wind, always check the leeboard first and make sure it is down.
It is possible to cleat off the lanyard to make sure the board stays down but you must remember to release it before running into shallows. I don't do that myself. Instead I prefer to run the lanyard back around an oarlock and into the cockpit. The oarlock acts as a turning block. Here is a photo of Herb McLeod's AF3 and you can clearly see the leeboard, upper leeboard guide, pivot bolt, and the lanyard running aft to a cleat which is handy at the back edge of the cockpit.
Again, usually on a boat like AF3 I would run the lanyard through the oarport and around the oarlock (Maggie the Dog would not appreciate that) and not cleat it off. But I do use a cleat on the forward end of the upper leeboard guard. I can secure the board in the up postition by leading the lanyard forward to that cleat. But in normal use the board is cleated up only while trailering.
Birdwatcher type boats have a problem with a leeboard like this in that there is no convenient access to the outside of the hull to handle that lanyard. My suggestion would be to run the lanyard through a small hole in the side of the hull which is kept radiused to act like a bearing. Pull the board down at any time that way without leaving the inside of the boat. No need to ever pull it up except to trailer.
No one has done that but some of those boats have lanyards running fore and aft to be captured by cleats on the fore and aft decks. So you can pull the board around like a puppet in any direction. Here is a photo of Karl James' Jewelbox chuckling along. You can see here the leeboard, the upper and lower guard, pivot bolt, and a loose lanyard running outside the hull to a cleat on the aft deck. (There is also a line running forward but it's not really visible.) You can see there is no tension required in that lanyard to keep the board in the down postion.
WHAT'S THAT VIBRATION???...
This one applies to any foil running through the water such as leeboards, daggerboards, centerboards and rudders. It is expecially true for deep narrow foils of the type preferred for low drag.
If the leading and aft edges of these boards aren't properly streamlined they will vibrate. That happened to me in the original Piccup Pram which had a really long narrow board. I wrote to Bolger about the problem and his answer was something like this:
"Streamline the edges more. If it still vibrates, streamline it some more."
So I streamlined the edges and the vibration went away. Bolger has seen everything.
We recently learned an intersesting spin on this. Richard Spelling was having problems with his leeboard vibrating and was getting tired of streamlining the edges. About the third time he wrote me about the problem, I had just received an issue of Small Craft Advisor and there it was - a discussion about foil vibration by the racing boat designer Stephen Baker.
Here is what Baker said:
"...A thin trailing edge, if faired into the shape properly, is a must. Do NOT round the trailing edge, rather cut it square and thin, and then bevel it about 30 degrees (doesn't matter which side) to stop it from vibrating at speed..."
A few days later Richard wrote me back, "Thinning and beveling worked pretty well. All leeboard vibration gone. Thanks guys."
Philsboat
Plans for Philsboat are $45.
1may22, AF3 Capsize, Blobster
1aug22, Horsepower, Oracle
