(1 April 2020) We recall a great tale of two totos. The 15 April issue will look into the mysteries of water ballast.
REND LAKE 2020...
Wojtech Baginski dreams of changing his sailing rig on his Robote. Wants smaller area and move mainsail forward to keep from hitting his head. Looks like he is racing himself, doesn't it.
jim@jimsboats.com
Tale Of Two Totos
MARC SMITH from Bloomington Indiana...
... attended the very first Rend Lake Messabout way back when. And the second year he arrived towing his new Birdwatcher with a pair of Totos strapped to the Birdwatcher roof. That was in the early 1990's. The boats were built by his daughter and her friend, under Marc's watch, and he recently found these old photos of the projects. This was way before this website and before digital for most of us. But his story still stands very well...
"GIRLS, AGE 11, BUILD TOTO
Small boat tinkering led me to the Small Boat Messabout in southern Indiana and Illinois. Phil Bolger�s building ideas were key to this movement. I built his Windsprint and later his iconic Birdwatcher. Accompanying me on these weekend messabout excursions was my eldest daughter, Kim, who enjoyed the camping, boating, and attention from the adults.
At the conclusion of her sixth grade I ask her if she and her friend, Hadley, would like to build their own canoes. They both jumped at the idea! It was about three weeks before our next Small Boat Messabout and they wanted to build the boats to take along. We chose Jim Michalak�s Toto and I emphasized to the girls that I would only supervise their work but they would do all the building themselves. They enthusiastically agreed.
First, I showed the girls how to measure and lay out the offsets from the plans and they went to work on the scarfed sheets of Luan.
Next came the cutting out of various parts. Using the jigsaw was a new experience but they mastered it quickly!
Then they glued the frames.
Attaching the sides and bottom to the frames and it is starting to take shape!
The last panel is inserted and with one girl below passing the copper wire through pre-drilled holes and the other on top twisting them together they completed the stitching process.
One boat is duct taped and turned upright ready for filleting with filled resin.
Inverted once again, the wires are trimmed and the seams smoothed for the outside taping to proceed. Here the seams are taped and the bottom is glassed. When dry they will begin painting them with their color of choice.
Let the painting begin!
With the threat of rain they moved to the garage and decided to paint the interior white to accent the natural wood of the frames.
Painting the paddles...
NICE JOB LADIES!!
It is finally time for sea trials!
And on the launch ramp at Rend Lake three weeks later!
What a sense of accomplishment for two industrious young ladies!
Building confidence and memories for years in the future!
Marc Smith,2018 Bloomington, In.
River Runner
He sent me some photos of a paddlejon he had seen recently and a sales brochure. I tried to copy the lines, thinking all the time that these boats are a lot more subtle than you might think. At the time I had no real Lowe around to study but the brochure left me with the impression that the paddlejon was perhaps a regular small power jon made long and double ended with swept up lines both fore and aft to allow easier paddling. But it is not quite a true double ender in that the stern transom is raked for the usual 15 degree motor mount. As far as power goes, a boat like this won't plane nicely at all, trying to stand on its stern at the least excuse, so I say 3 hp max.
Jim Hauer built the prototype in Green Bay and sent these photos. I think it came out exactly as hoped. Remember, this is not really a rowing boat as much as a floating boat so the face forward rowing will be used more to steer than to propel. The photo of the man paddling in the stern shows that the aft transom is still up giving good flow lines there, unlike a square stern power jonboat. Under power Jim said that 2.5 hp is about all you can take, the boat not behaving well above that.
Anyway, River Runner uses five sheets of 1/4" plywood. The idea of the light ply is to keep the boat light enough to manhandle into a truck or onto a car roof but it will take a diligent builder to keep it light. I suspect the aluminum original would be no heavier. Simple nail and glue construction.
River Runner plans are $20 when ordered direct by mail from me.
15aug19, Rowing1, Cormorant
1sep19, Rowing2, OliveOyl
1dec19, Taped Seams, Ladybug
15jan20, Trailering, Robote
1feb20, Bulkhead Bevels, Toto
15feb20, Cartopping, IMB
