(1 October 2019) We go OliveOyling in Canada with Herb McLeod. The 15 October issue will keep continue the OliveOyling.
Left: Herb McLeod has a neighbor with a fancy camera. Indeed!
Herb's OliveOyl
HERB MCLEOD...
...has been a key help to us boaters for a long time. In my case he has prototyped different boats going back to the AF3 long ago, and then he practices capsizing in the cold Canadian waters and writes about it. He did the OliveOyl prototype last year and has spent the summer in some serious testing of different rigs. So read on and learn. I think there will be two more episodes as later he does a junk rig capsize and then some junk rig testing with gps tracking.
Herb Wrote...
Hi Jim,
So far I have only had 5 full days sailing the junk rig but I will give you my impressions so far.
I built the Chinese lug sail after sailing with local enthusiasts who likes to experiment with different rigs had me out on one of their boat for a day of sailing: http://www.workingsail.com/index.html
The Chinese lug in made on the lines of a Duck Works article by Albertan Mike Mulcahy. I used a 10 oz 12' x 15' canvas painting tarp bought at Home Depot rather than the poly-tarp. To make for a rapid setup I did use the snap buckles and snap hooks as he showed in his article. I also added the Gurney Flap and built in some camber. I used half the camber that he suggested for the poly-tarp which turns out to have been a bit of a mistake. My experience with the canvas lug sail is the broad seam darts are made at about half as wide as one would sew into Dacron. The canvas stretched out to give what looks like a nice belly to my balanced Lug. So far the 22 inch wide panels on the Chinese lug have shown no tendency to stretch even in +20 knot winds.
The tie dye colour was a result of my attempt at mixing a canvas waterproofing with a burnt sienna pigment. On my test batch it worked fine but when I tried to make a larger batch the pigment settled to the bottom of the can too quickly. The top 4 feet of sail have a much more even colour as here I learned to mix up only half a quart at a time and I would keep keep the pigment suspended by swirling my brush each time I dipped it into the can.
I also see that one of my spars is not in the right place. Something that can happen when building a sail in a space that only allows layout half of the sail at a time :-) One suggestion that I have since from from a a local fellow sailor that likes to experiment with different rigs is to build all the sail panels separately and then lace them to the battens.
The Mike Mulcahy article: http://www.duckworksmagazine.com/06/howto/junkrig/index.htm
I found the read in Wikipedia about the Gurney flap interesting. I suspect you already know the story about Dan Gurney: https://en.wikipedia.org/wiki/Gurney_flap
Comparing the three rigs:
Weights:
the professionally made Dacron leg-o-mutton sprite sail on the mast with the sprite boom and halyard weighs 34 pounds.
The 10 oz canvas balanced lug sail with spars weighs 24 pounds. (Plus mast 45 pounds)
The 10oz canvas Chinese lug sail with spars and lines weighs 36 pounds. (Plus mast 58 pounds)
(The 16 foot mast that I use with both the balanced lug and junk sail with halyards and lazy jacks weighs 21 pounds.)
Set up time:
Set up time is fastest with the leg-o-mutton as I leave the sail on the mast by rolling it up from the clew and then wrapping it with the halyard and snotter. The balanced lug takes a minute or so longer as I have to rig the lazy jacks and the Chinese lug only a couple more minutes again as I have to snap the parrels together. If I was trailer sailing and going out only for a quick sail I would choose the balanced lug. If I was expecting a lot of wind I would take the extra setup time and use the Chinese lug.
Close winded:
Sailing the leg-o-mutton, it tacks at about 100 degrees on my compass. Both the balanced lug and the Chinese lug are very similar and need about 105 degrees between tacks. I am using my compass to measure these angles.
Reefing: We had +20 knot winds the second day and I was impressed as to how docile the Chinese lug was. We were able to decrease or increase the sail area on the fly something that could likely not be done with the balanced lug and definitely not with the leg-o-mutton. At one point we reduced the Chinese lug sail by reefing the three bottom panels and were still able to sail to windward in the +20 knot winds. The Chinese lug sail enthusiasts with me on OliveOyl noted that this was interesting as the sail area was probably close to the windage of the hull. Also raising and lowering the Chinese lug in a blow was was not as dangerous as with the balanced lug as it is at all times well tamed. The one time I came close to capsize with the balanced lug was when I was raising the sail and when it was about half way up I was caught by a strong gust of wind. The sail then billowed out like a spinnaker and came very close to dumping the boat on its side. I saved the situation by letting go of the halyard and dropping to the floor to get my weight as low as possible.
AF3 and OliveOyl: On another topic Gord was by with his 20 year old AF3 on his way back from Qu�bec to Alberta. We had a good deal of wind and were able to sail the two boats side by side for a day. I have attached a photo of that occasion. Below is what I wrote to the Working Sail group following that event:
Gord arrived at lac McA with his AF3 and we went sailing with both boats using the exact same leg-o-mutton sails on both boats. In the light wind the AF3 was a bit faster than OliveOyl but when it started to blow Gord had to reef the AF3 to keep things from getting scary while OliveOyl was able to comfortably carry the full rig. We later changed masts on OliveOyl and put on the 110 square foot canvas lug sail.
Generally we found that we preferred the lug sail as the mast is easier to handle. Set up is a slightly slower with the lug sail as there are the reefing lines to deal with. That said the lug sail easier to raise and lower in the windy conditions and we could heave to with the lug which I have not been able to manage with the leg-o-mutton.
Next I will have to capsize test both the balance lug and Chinese lug for a comparison. When I get some pictures I will send them.
Cheers,
Herb
Larsboat
Larsboat plans are $20.
