(1 August 2019) We review sharpie sprit sail rigging. The 15 August issue will take a look at rowing.
Left: Wojtech Baginski's Robote set for a brisk workout, in Warsaw, Poland.
Rigging Sharpie Sprit Sails
BACKGROUND...My first homebuilt boat, in 1981, was a Bolger Teal rigged with a 59 square foot sharpie sprit sail. Next boat was the Bolger Jinni with a 96 square foot main and small mizzen, both sharpie sprits. Later came Birdwatcher with a 126 square foot sharpie sprit. I've used the sharpie sprit on lots of my own designs thinking it about the best sailing cheap rig (although it has its disadvantages too). In this essay I'll pass along what I think I've learned about it.
THE BASIC ELEMENTS...
THE MAST...
THE SAIL...
MAST/SAIL ATTACHMENTS...
THE SPRIT...
SPRIT ATTACHMENTS...
ORACLE
