(1 December 2019) We review taped seams. The 15 December issue will review joining plywood sheets.
REND LAKE 2020...
...will take place on June 12 and 13, always on the weekend before Father's Day weekend. I promised to remind all of us to try to get the good campsites. They are sites 24 through 30 and especially 26 through 29 if possible, this at the North Sandusky campground at Rend Lake. Let's give it a try. This is not really organized but if you nail one down, let me know. I will be trying too.
Taped Seams
HISTORY...I remember seeing taped seam construction first in an article in the old Small Boat Journal about Sam Devlin's efforts. That was probably about 45 years ago (time flies). But by then the method was old in England. I think it was "invented" by an Englishman in the late '50's and was quite common there by the 70's. The Mirror dinghy was done that way with kits meticulously made from plywood with notches and tabs to fit the pieces together like a balsa model airplane kit. I visited England in 1982 and saw hundreds of Mirrors stacked on end at Portsmouth. Around the same time kit makers like Clarkcraft were selling kits of kayaks made that way but they called the method "sewn seam" which I think threw some of us off. "Sewing plywood together with wire - that sounds hard!" I said to myself. Harold Payson and Phil Bolger tried it in the early 80's with several designs that are still around. Harold called it "tack and tape" because at the time he didn't like using wires to temporarily fasten the panels together. He used small nails and adhesive tape, then hot melt glue, but eventually came around to using wire like everyone else.
Next for me came the Payson canoe, multichine taped seam boat. Also built of cheap plywood with polyester resin and automotive Bondo in the late 80's.
Next for me was Piccup Pram in 1989. Cheap plywood and polyester resin and Bondo again. I still have it. It's seen a lot of use.
Next I think was Toto which sort of evolved from the Payson canoe. Cheap lauan plywood with epoxy resin this time but still with Bondo fillets. The plywood delaminated after 20 years (unlike the fir and pine ply used in Piccup and Roar) but the joints were still very solid. When I cut it up I sort of knocked out the remaining plywood and was left with the skeleton of the seams still intact.
The last was WeeVee which used cheap lauan plywood and reverted back to polyester resin and Bondo. Gave it away after ten years or so.
"What's with all the polyester resin and Bondo?" you ask. Anyone who mentions using these in the rec boatbuilding newsgroup gets pounded and made fun of. Even years ago Payson was attacked for building with polyester. I didn't know any better and have really had no troubles. Whenever I use one of my polyester boats I tell it, "You'd better start falling apart soon. You're making those experts look bad and they are going to pound me on the newsgroup and make fun of me." So far my boats haven't listened.
Polyester has certainly worked OK for me. My boats are stored under cover as a rule (although some have been outdoors for months at a time). That may be a factor in their longevity with polyester. Where I live you can never expect to get your money back on a homemade boat, even the cost of materials. I think when we started years ago we got polyester for $13 a gallon (good stuff too) while epoxy went for about $70 a gallon. Now we know epoxy got cheaper while polyester got dearer. So now I advise epoxy and it really is better. Of course if you are using expensive plywood, etc., you need to use epoxy.
(This is how I do it. Others have their pet methods.) Not much to it. My boats are all designed from the inside out, so to speak. The dimensions are arranged such that the panels should make kissing contact on the inside edges as shown above. Usually the project is upside down at this time, sides, bulkheads stem and stern fastened together, and you are trying to put the bilge or bottom panels on with taped seams. You put the panels into position and drill pairs of holes about every 12" around the perimeter, about 1/4" in from the edges. You take pieces of soft wire, I prefer stainless steel aircraft "lock wire" but almost any wire will work if it is pliable, and cut lenths about 6" long and form them into a long U shape like a staple. Get inside the project and push the wire staples up through the holes so that the ends now stick out through the outside. Get outside with a pair of pliars and twist the wires until they tighten the panels together. If you overtighten you might break the wire or tear the wire right out of the wood. Eyeball the joints to make sure they are fair. You can open a joint up to maybe a half inch if it will help. If two panels are binding too tightly, you can run a saw down the joint to loosen it up. I think a small gap or V is preferred because it allows resin to flow in and seal the ends of the plywood. But the joint fit is really not too critical.
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
Ladybug
Plans for Ladybug are $40.
15aug19, Rowing1, Cormorant
1sep19, Rowing2, OliveOyl
