(1 May 2020) We look deeper into the mysteries of water ballast. The 15 May issue will discuss mast tabernacles.
REND LAKE 2020...CANCELLED!!
..I see no way that any gathering will be safe by mid June, at least not in southern Illinois where the virus is still gathering steam. Campgrounds are still closed, no word on reopening, and some launch ramps also. First miss in over 30 years, but we will be back next year.
Left: Ross Lillistone built this Mayfly about ten years ago in Australia. He writes, "Me being skippered by my five year-old grandson. He has been in sailing dinghies since he was six months old....longitudinal trim is so important, and she is sailing beautifully in these conditions."
- Water Ballast Details
- Blobster
WATER BALLAST DETAILS...
SO you've decided to try water ballast. How to do the ballast box? How to flood and drain it? The only boat I've designed with water ballast (so far) was Scram Pram. There were two Scam prototypes built and the first one had the water ballast and second didn't. Here is a letter from the first builder......
.........My sage and good friend, Tim Webber, keeps sending me articles on water ballasting from his homesite. I built a waterballasted boat called Ghostling(design is listed as Scram Pram on Jim Michalak's page).
Of the articles I read I have no real substance of disagreement. However, my experiences with Scram Pram may add these different observations.
First, it is highly impractical to be shifting water ballast from one side to the other unless the boat is: 1) large and 2)on long tacks. Even given these requirements it is still a risky business to make an emergency maneuver with this profile. Before I leave this subject, I would like to point out that of the articles I read I did not find a mention of stress loading on the rigging caused by loading one side and making the other bouyant. Having collapsed two mast supports on previous crafts, this is a phenomenon that I've had some time to contemplate.
Next I want to approach the recurrent subject of water ballast taking up too much space in the craft. If one is going to water ballast they should choose a boat with not only the right shape, mainly wide and fairly flat bottom, but also a design that could integrate the tanks into the structure. For example, Scram Pram easily takes on 300 lbs of water ballast and it actually improves the interior of the boat by adding a strong internal keel, comfortable seats/beds, and providing foot rests. In this case the tanks were in the design from its' inception and of course, Scram Pram is 100% waterballasted. Also, she moves exceedingly well in light air whether ballasted or not.
On Scram Pram I devised a 3 tank system(the third tank being Jim Michalak's idea to be used as a trim tank). Scram had two saddle tanks forming the beds, seats, foot rests and internal keels.
The two saddle taks accounted for about 250 lbs. of the water and each one had 3 apertures in it. 1) first there was the obvious hole in the bottom at the deepest point of 1/2 inch and it filled it like a water fountain. 2) Next was a port hole directly over it with a see-through cover just large enough to put you hand through to put in a stopper if you cared to. This was not necessarry since the tanks were capable of holding their fluids by sheer force of vacuum. 3) The third apeture was at the front of the tank and had a PVC pipe of 3/4 in. rising a foot or more with a screw-on cap with petroleum jelly kept on it as well as the screw-down port cover to prevent air leakage; remember, a tight seal is necessary if we are going to create a vacuum.
This arangement fills and empties quickly giving one the option of using no ballast at all on those light days when you have a number of passengers that you can shift from side to side catamaran-style and the see-through port allows you to check the status of your tanks to see if they are loosing their water and if your vacuum is working properly.
One thing I did not test with Scram Pram that should work is the addition of a bicycle valve at the top of the PVC cap. This simple addition would allow one while under way to "blow" the tanks submarine style when the wind dropped, you picked up more gear, or for those suicide jockies, just to blow the leeward tank to gain more upright sail area at the cost of some stability on the boat.
The air used to empty the tank could come from a compressed can, an electric pump or a manual foot pump. The last two options are certainly inexpensive enough.........
Thanks, -
I've never seen the installation mentioned above, but the Scram tanks look like this:
My idea at the time was to fill the tank by removing the deck plate, reaching into the tank and pulling the drain plug. Then stand by as it fills to replace the plug just as the tank is full. If the top of the tank is above the normal waterline, the tank may not fill all the way and you have to top it off with a bucket and replace the deck plate. If the tank top is below the waterline and you forget to replace the plug, your boat could sink. Anyway, I think he system would work with very cheap stuff and no external plugs to deal with. (I'm not sure how Bolger did it on Martha Jane?)
What the Texas Scram builder did was the above but he added a standing pipe with something like an airtight valve on the top, as I understand it. So he can fill the tank by opening the bottom port and let the water rush in while the air rushes out of the open tube. When full (assuming the tank top is below the waterline) the tube is sealed and the water somewhat trapped in the tank. It's very much worth a try and is a noble experiment in that it is cheap, and that if it works is an improvement, and if it doesn't work it can be returned to the original design very easily.
I don't know how much testing the Texas Scram got, but one thing I would watch out for with the tube system: On a long, long tack with lots of heel, the up side tank may not hold its water by vacuum alone. It may dribble out slowly. Solution would be to just use the plug. But for a fin keel water ballast system designed merely to right the boat in a knockdown, wouldn't this system be perfect?
EFFECTS ON A REAL DESIGN....
Last issue we used the Hullform6S program to look at stability of a simple rectangular "boat". Let's look at a real design. The example here will be Jukebox2. And we'll put in some spice by comparing the results with Jewelbox, a very similar boat that used the unballasted Birdwatcher cabin system.
Here are some rough cuts at the weights and CG's:
Jukbox2: Item .Weight(W) .Height above bottom (X) .WX Hull 700 21 14700 Bottom 100
4 400 Mast 50 100 5000 Yard 12 210 2520 Sail 5 150 750 Boom 16 70 1120 Crew 200 36 7200 Ballast 300 3 600 Totals 1380 23.4" 32300
Jewelbox: Hull 700 21 14700 Bottom 100 4 400 Mast 50 100 5000 Yard 12 210 2520 Sail 5 150 750 Boom 16 70 1120 Crew 200 18 3600 Total 1080 25.9" 28090
Running the above weights and CG's through Hullforms and I get the following righting moment curves:
....COMMENTS...
Both boats have the same basic length, cross section in the cabin, and bottom shape. They have identical sail rigs. In the weights you will see the item "bottom". Both boats have a thick 1" bottom and this separate item is supposed to account for the extra weight there. As for the crew situation, it changes all the time, of course, but the crew on Jukebox is above the overall CG and adding more crew makes it less stable. For Jewelbox the opposite is true. Adding more crew to Jewelbox makes her more stable since the crew sits below the overall CG. Also, in the analysis of Jukebox, only the watertight volumes of the hull were used in the Hullforms file. If you look at the gif of Jukebox below, Craig O'Donnell has presented one that shows the watertight volumes. For the Jewelbox, all the volume is watertight except for the small bow well.
...JUKEBOX2...
I had hoped this boat would be self right up to 90 degrees but it looks like it goes to 80 degrees in this ballast situation. (What does that mean? Chapelle considered righting from 45 degrees of heel was fine for a sharpie while today's bluewater sailors like to self right quickly from 140 degrees of roll.) I think another 100 or 200 pounds of ballast is needed to get it to 90 degrees. Although this discussion is about water ballast, any ballast material of the same weight mounted inside the hull at the same location will have the same effect. (The Jukebox2 plans show the ballast as steel bars bolted across the bottoms of the bulkheads.)
I didn't have a chance to show a "no ballast" situation for Jukebox but the numbers show that removing the 300 pounds of ballast reduces the weight by 300 pounds and raises the CG almost 6". Maximum righting moment goes from 1170 ft -lbs with 300 pounds of ballast to 820 ft-lbs with no ballast (both at 20 degrees heel). Worse yet, the unballasted boat will capsize at 50 degrees of heel. So here the ballast seems well worth it.
I might add that the 300 pounds of ballast, if done with water, would be about 5 cubic feet. This boat is 5' wide on the bottom so the ballast tank might take the form of a full 5' width box, 6" high and 2' long.
...JEWELBOX... I think the fact that the Jewelbox righting moments are generally less than Jukebox's in the usual sailing range is mostly because she is about 30% lighter. If she were loaded with two more people and brought up to a weight about equal to Jukebox's I'd think she might be even stiffer than Jukebox. But the most valid comparison might be with the unballasted Jukebox which weighs the same as the Jewelbox. The advantage of the Jewelbox is that it won't flood and maintains a small righting moment past 80 degrees of heel.
Blobster
Great job, Miles!
Plans for Blobster are $45.
15aug19, Rowing1, Cormorant
1sep19, Rowing2, OliveOyl
1dec19, Taped Seams, Ladybug
15jan20, Trailering, Robote
1feb20, Bulkhead Bevels, Toto
15feb20, Cartopping, IMB
