(15 March 2019) We look at the shape of underwater boards. The 1 April issue will be about polytarp sails.
REND LAKE 2019...
Left: Phil McNamara, and cat, have this fine Piccup Squared in the water. More on this one later.
Underwater Board Shape
As an example, let's use Frolic2. Her board has 4.4 square feet of area immersed and it is 3.5 feet deep. So the aspect ratio is 2 x 3.5 x 3.5/ 4.4 = 5.6. Now let's say we wanted to guess at leeway on a close reach in 10 knots wind, and we'll assume she is going 4 knots at the time. Frolic2 has 114 square feet of sail and 10 knots produces about .5 psf on a typical good sail, so that is 57 pounds of sail force. We'll assume that all of that force is counteracted by the board. So the overall pressure on the board is 57/4.4 = 13 psf. Now we need to calculate the value of C for the fin. Remember that the psf on the fin is = 2.86 x V x V x C. Using V = 4 knots, we can solve for C and get C = .28. Now get into the aspect ratio figure, guess where AR = 5.6 might be and it appears that the leeway angle would be about 4 degrees.
This sort of analysis flies in the face of some designs. As mentioned earlier, the shallow keel can work very well if given enough area. But I've seen designs with "keel runners" and such which I think are just small projections off the bottom. Given what we have seen here I don't see how they can work effectively. I've sailed boats with skids and external chines which approach those things but my boats always had leeboards or centerboards too. If you think the skids and chine runners are effective, you need only take one of my boats out, get close hauled, and raise the leeboard or centerboard to see what happens. You'll slide right off!
Matt Leyden's Paradox uses "chine runners", small fins on the side of the hull's chine. So on a 14' boat the chine runner was about 2" square and maybe 5' long mounted on the deepest point of the flat bottomed hull, not on the bottom of the hull but on the side at the chine. I saw one at Sail Oklahoma a while back and Matt was there to give a talk. Great to hear him. One thing of note was that the Paradox sails at a very high weight for its size. Matt said the chine runners work if the draft is about 25% of the beam. So a 4' wide boat would need a 1' draft to be effective by Matt's suggestion. Most small flat bottomed boats are sailing with a lot less than that, maybe 4 or 5 inches would be a most draft for say a 14' boat with a 4' beam. One other boater thought Matt also uses a trick shown by Bolger in the 1980's, which Bolger learned from watching some very old designs, of setting the sail area well aft and using a very large rudder which helps carry the side load of the sail. If you were to just see a photo of Paradox in the water you would see none of those features, chine runners, deep draft, and large deep rudder.
Harmonica
HARMONICA, MINISHANTY, 13' X 5', 400 POUNDS EMPTY
Harmonica is a tiny shanty boat that sleeps two in its cabin. There is a porch up front suitable for lounging and a small room in the stern for the kitchen and the water closet. I think it is arranged so that two people could wait out an all day soaker without feeling too pressed. For protected waters only. I've been asked more that once if Harmonica would be OK in the Ohio River, etc.. My answer is no. In calm weather you might get away with it but you always run the risk of huge wakes, especially from large motor yachts. The prototype Harmonica was built by Chris Crandall of Lawrence, Kansas.
This boat was originally called Fusebox. It was intended to be an electric boat for the wonderful little conservation lakes we have around here. But later I thought that the electric scheme was strained because few trolling motors could push this box on a windy day. And because I noticed that none of the local conservation lakes have electric plugs at the docks, so recharging the batteries there would not be possible. Putting a gallon of fuel on board is a lot easier than taking an 80 pound battery home. Chris used a 1 horse Tanaka and that was about the minimum required, pushing the boat at 2 or 3 mph. At the same time I would say that 5 hp would be a reasonable maximum. You don't need much power or speed because you never can go more than a mile in any direction in the lakes I'm thinking of.
I also heard from John Applewhite, of Gainesville, Fl., who built the Harmonica shown in the photo above. He had quite a bit of shantyboat experience and also some electric experience. He used a 3 hp Minnkota and two golf cart batteries, probably about 200 pounds of gear. John said this electric is used nearly all the time with great satisfaction but he also has a small gas outboard on the transom as a backup.
John also wrote, "...The entire family (two adults and two children) has spent the night on Steel Will. I put 1x2's between the slats in the two forward bunks and created a single bunk that is five feet wide. We have found that the thick cushions sold to cover lawn furniture very adequate mattresses for boats."
Harmonica soaks up four sheets of 3/8" plywood and six sheets of 1/4" plywood and uses simple glue and nail jigless construction. Blueprints with keyed instructions are $25.
