(15 Febuary 2023) We discuss trailering plywood boats. The 1 March issue will cover rudders.
REND LAKE MESSABOUT 2023...
...Lets try it again. Rend Lake 2023 will take place on June 9 and 10, always on the weekend before Father's Day weekend. I promised to remind all of us to try to get the good campsites. They are sites 24 through 30 and especially 26 through 29 if possible, this at the North Sandusky campground at Rend Lake.
Left:.
Tom Amara's beautiful Blobster, and its reflection. Great job! I am told the boat is in New York (I think all the other Blobsters are in Australia) and had a season's sailing. Tom sent more photos of details which will appear later.
Trailering Plywood Boats
...WHEN TO TRAILER...
...TOW VEHICLE...
...TRAILER TYPES...
A low trailer is best.
...CUSTOM BUNKS...
...TONGUE WEIGHT...
...NOW FOR THOSE BUNKS...
WINCH POST
...GOAL POSTS...
...SIDE BUNKS...
...TIE DOWNS...
...LIGHTS...
...FINALLY.....
IMB
IMB plans are $30.
1may22, AF3 Capsize, Blobster
1aug22, Horsepower, Oracle
15oct22, Figuring Displacement, Jonsboat
1nov22, Lugsail Jiffy Reef, Mayfly14
15nov22, Sharpie Reefing, Piccup Pram
1dec22, Making Oars, Batto
15dec22, Taped Seams, Sportdory
1jan23, Rowboat Setup, Normsboat
15jan23, Sail Area Math, Robote
1feb23, Bulkhead Bevels, Toto
